I cut the hole on the opposite side for the floppy. Then I shined a flashlight through.
Next, I cut the hole out of the front.
Fixed the pin stiping.
And here it is from the inside. As you can see, I'll be avoiding the use of drive bays to keep the clutter to a minimum.
I was going through some of my supplies when I found a box of handles!
Also, here's the power switch I want to use. Any idea on where I should mount it?
