i was just about to do my first mod.and i am wondering if anyone knows the right tool to use to sidewindow mods.thanks.
Athlon 3800+::7300Le::2x1GB OCZ Platinum::160gig Maxtor
Go to radio shack.. ask for a "nibbler".. small tool that works pretty well for lite steel.. cost of about 10.00 usa.
are you trying to cut metal, plexi?
i understand nibblers are great for cutting metal, but they won't do jack about cutting your plexi :p
plexi you can score and snap if it's thin enough, cut with a rotary tool, jigsaw, etc. just got to use the right blade for the power tools or it'll melt and turn out poorly.
I used this tool to cut my window:
If you are just very carefull and take your time and always wear protection (for your eyes) it should be no problem...
you can also use a dremel-like device...
I would suggest a dremel with reinforced cutting disks, a coping saw or a nibbler.
