Ok I just finished my computer case, complete with a window. What I want to do is add the name of the project to the window. "Phaginal Ownage" if any of you were wondering.
Anyone know how to do it, without etching it?
If you want to do it really cheap:
1. buy a sheet of sticker-paper (about... 5 cents or so?)
2. Print your logo / name on it
3. cut is out
4. stick it on your window
did that with my mod, look nice, BUT the corners will come loose in the end.. Actually I want to raplace it with a vinyl or something... when I have time...
But if you're tight on money, it's a good solution...
Phage: a virus whose host is bacteria.
I'm not sure this is what you meant my this, but at least it does have another meaning so you can tell your grandma.
A couple layers of paint gloss will keep a decal in place.
I've been looking into frosting for my next window, you might consider that too.
Test your setup first. Chemical interaction isn't fun.
