I woke up the other morning to a strange silence that I haven't heard in over a month...my computer was turned off. I thought it was odd as it was on and folding when I fell asleep. After it failed to post I noticed only 1 led was lit on the board and it happens to signify a CPU issue. I was about to pull the mobo when I noticed some rather naked pins when I disconnected the cpu power line off the mobo. Apparently the plastic has melted off the cable and is still stuck in the mobo connector.
I've been using the same PSU for many years and a several mobo span. The first mobo only had a 4pin connector so the 8pin cable got chucked in a box somewhere and forgotten. The 4pin is rated to 192W (16A) max which I've never come close to with any OC. (My 1090t was at 177W (14.7A) when this occurred...which is the highest draw I've ever personally experienced.) I never felt the need to dig it up after buying boards with 8pin connectors...in hindsight I wish I had.
Well, I dug it out and tried to plug it in, but there is just too much melted plastic in the holes. So, does anyone have any suggestions to get that plastic out or to replace that power connector? I don't have any way of testing the components so my first goal is to fix that power connector and make sure power is getting to the CPU...through an 8pin line this time! If it still doesn't work after that, then I suppose I'll be upset.
