As some of you may have seen pics in my contest entry, you didnt have the chance to comment and I didnt explain much either. So here it is:
Specs:
XP 3200+ with TR SI-97 hs / Silent Cat 90mm fan
MSI K7N2 delta-L
Corsair PC3200ProXL 2225
X800 Pro @ 560/1060 with Silencer 4 modded for better airflow:p
Audigy 2 Platinum
40Gb + 120Gb SG Barracuda
LG DVD rom and a RW
Aerogate 2
OCZ Powerstream 420W
Now what Ive done:
Ripped out the Fan grills and the filter from the front
Sleeved ribbon cables(ide and audigy cable), front panel wires:
Cable Mangement:
Extra power lines tucked on top of the psu and the right top corner, cut out on the mobo tray.
<- isnt that mirror finish PSU a beauty?
Thats it for now, hope you enjoyed.
Now you can throw those tomatoes at me
