So, I know that if I wire batteries together in a serial configuration the voltage will increase to a total of the combined voltages of the batteries. But how does it work?
My train of thought is that batteries contain two chambers (+ and -) and the electrons want to travel from - to + in order to create an equlibrium. So you make a connection between them with something in between that is then powered by the passing electrons. But that would mean that if I stack a few betteries on top of each other the electrons would simply travel from the topmost section to the one at the bottom of the stack while the batteries in between is shorted out instantly. This is obviously not how it works so there must be something I'm missing with this theory. Does anyone of you know how it works?
-Diamon
