Results 1 to 10 of 10
Thread: computer problems
    Water Cooled pcclan's Avatar
    Jan 2009
    Edmonton,Ab
    Default computer problems
    my computer randomly freezes and restarts if you need more info i will proved specs are in the little tab
    Quote Originally Posted by lastweek View Post
    Not only will it probably catch fire to your house, it will probably shoot peices out of your case and kill your cat. make sure you video tape your expierment.
    Quote Originally Posted by StormRider View Post
    Write your will before you turn it on
    Oct 2008
    MD, USA
    Default Re: computer problems
    What OS? Does it do anything specific when it freezes? Are you doing anything consistently when it restarts (I'm guessing not since you say randomly)?
    My first two thoughts are bad RAM or overheating. For RAM, grab a memtest86 disk and let that run for a while. For overheating, have Speedfan (or your preferred temp monitoring utility) run while you use your computer and check it occasionally. If you see temps getting too high on anything (what 'too high' is depends on the component), check the cooling for that part.
    --Benjamin Franklin
    Jan 2009
    Edmonton,Ab
    it's not over heating and it's not bad ram. i am using windows 7. i did do a memory test and it passes
    Jun 2008
    MA
    power supply getting weak maybe? my parent's computer started randomly shutting off the other day, turned out to b the PSU. popped a new one in and its good
    Oct 2008
    MD, USA
    Try running a linux live-cd for a while. If it still does it then you know it's a hardware problem. If it doesn't, it might be software.
    EDIT:
    Actually, the PSU is a good point. What PSU do you have running that?
    --Benjamin Franklin
    Jan 2009
    Edmonton,Ab
    i have an enermax infiniti 720 watt
    Overclocking Guru Trace's Avatar
    Aug 2007
    California
    Probably a little underpowered
    Quote Originally Posted by Lothair View Post
    I guess it's just widely used and has had some of the best people in the world work on it, costing a ridiculous amount of money, for no actual reason. :/
    Have you checked out the front page lately?
    Projects:
    Moe's Tavern | Sponsored by: Mimo Monitors, Crucial, Thermaltake
    Book Of Knowledge
    Jan 2009
    Edmonton,Ab
    how is it under powered all i did was add more ram and then it started to act up
    Feb 2008
    Detroit, Michigan
    Quote Originally Posted by pcclan View Post
    Is the memory getting enough voltage? I assume you already reseated the memory in the sockets. It is a strange problem that you have.
    Help my mini city
    Jun 2008
    MA
    you've also got 2 different types of ram, each ma require a different voltage. and TBH, you don't need 8GB of RAM 4 is more than enough. I've got 6 in mine and I hardly ever exceed 2GB, even with sketchup, photoshop, etc. what gets it the highest actually is MW2, gets it to almost 3, but even then there's over 1GB left. I say take the second 4GB set out (seeing how it's the most likely culprit - you put it in then started having issues) and sell it or save it for your next build
