I purchased these a pair of these a while back for a car audio project:
http://www.parts-express.com/pe/show...number=264-844
Reviews both on parts-express and other DIY speaker sites describe these drivers as nothing short of amazing.
I'm in the middle of building up a shop right now, and realized I need some tunes. I hooked these up free air using a sonic impact t-amp I had packed up in a box, and as soon as I fired them up, it was like the gods were singing... I mean, these things sound AMAZING. There's just no adequate way to describe them, although you can get somewhat of an idea from reading reviews.
I wanted to build an enclosure set worthy of these drivers, but my budget right now is zero, so I had to use materials I already had on hand. I had some really nice self-adhesive carbon fiber sheeting in a drawer, so I decided to incorporate that.
To start, I cut some 3.75" long sections of heavy wall carboard packing tube. To turn it into an enclosure, I made four MDF discs, then turned them into rings on the lathe. The front rings were bored out with 3" holes for the speakers, and the back rings 2" for the terminal cups. I added a lip on them so they would pop into the end of the tube tightly. After that, I glued them in place, and when the glue was dry sanded the OD smooth.
Then I wrapped the bare enclosures in the carbon fiber and trimmed the extra with the belt sander. I didn't feel like doing much work on the backs, so I just blacked them with magic marker.
Next I wanted to make some aluminum bezels for the front to hide the wood and tie in the enclosure with the aluminum phase plug on the drivers. First I marked the circles on a sheet .062" aluminum, and then used a hole saw to chop out the centers to match the hole in the enclosure.
After that, I trimmed the excess metal from the rings using the shear.
I chucked the rings on the lathe, and turned them down to match the OD of the enclosures exactly. That way the edge of the carbon fiber sheet is hidden, and the whole enclosure has smooth lines. I also traced the speaker mounting holes and punched them out with a hand punch... after that I transferred them on to the enclosure and pre-drilled for the mounting screws.
The speakers were mounted using wood screws (just like fermi... j/k), and some foam strip to ensure a good seal against the enclosure.
I made some triangle shaped sheets with some scrap pieces, and then rounded the corners. I hand bent them over a large round post, and worked them until they were curved identically. I had just enough carbon fiber left over to cover them, and after applying it, trimmed it using the same method as before.
You can't see it, but there's small rubber bumpers under each to make sure they don't slide around.
I took some final shots, but unfortunately they didn't show the carbon fiber weave as well as the above shots did.
