ok, i haven't forgotten about this project, just been awaiting funds to purchace parts, i've ordered some plexi panels and have had them cut to size, due to where they are going i wanted them to be perfectly square.
The supplier is called RED Ltd, look it up if your wanting plexi in the UK, they sell on ebay and it costs £1.50 for a a4 sheet and first 4 cuts are free.
I have uploaded my pics finally:
I do appologise for the quality of the pics, i haden't setup my camara phone yet, so it was just using standard settings.
All my parts arrived:
and i fitted the new HSF to check the system works:
not bad, dropped the idle temp from 60 to 32,
and now to add the new fan! this thing is mad, 120mm, 3 speed settings displacing a max of 79 CFM
and how it stands now its in the case, my god how this looks bad:
i got my switch from maplins:
I think these looks really nice, and will suit the case when its finished, theres also 2 Super bright LED's there in a plastic bag.
Now most front fasias i have removed are normally just clipped on, this thing is screwed on, but it is removed:
Now when i did this i didn't have my plexi (Still don't getting delivered soon) so i am using the one remaining blanking plate i have:
I am using it as a test for drilling the hole out, the hole needs to be 19.2mm but i only have an 18mm bit, so i had to file out out a bit:
And i attached the wires and tested it works:
And it works! success
Now then, all i need is my plexi, a dremel, some bondo, lots of sand paper and lots of paint. and were set!
I admit this isn't of as high callabir as the likes of most here, but i hope the end result will be of high quality.
