I will be fusing the connection from the pack to the controller. I think I may also fuse each module, just to be on the safe side.
For the material, I'm going to see how well the 1/4" can hold threading. I may just replace some panels with it; not sure yet.
They ran out of packs...and they don't have any in stock at their Hong Kong warehouse either...so if anybody wanted to buy 5Ah 5S Turnigy 20C packs, you're out of luck..
