I've been searching the net. . apparently It could be your video card, hard drive, or monitor.
IMO if it starts out with the noise and it goes away. . try a drop of oil in the fan.
Originally Posted by Crimson Sky
Long shot, but I'm with Sly.... I say capacitor.
Just a test... can you unplug the PSU, leave it a short while unplugged (60 minutes?)... then plug it back in.
When you re-plug it, check to see if it makes similar noises before you turn on the computer.
Just shooting some ideas...
You're in TBCS?
You do realize we're following a guy that's the
VP of Regional Sales for
Darth Harrington's Intergalactic Proton Powered Electrical Tentacled Advertising Droids
I'm just sayin'...
I'll say: unplug everything. even the cpu. keep only the PSU and the mobo (if you have a spare one; even better) add one component at a time till you find the faulty one.
(Don't worry about the beeps )
Edit: try with only the PSU, short it to put it on.
Edit 2: short the psu Link
I'm leaning toward your PSU, more then likely you've got a filter circuit going bad (could be cap or a choke)
Look at SLy's drawing and jumper pin 14 to 15 and power up the PSU see if it still makes the noise.
CrazyBillyBob
i have troubleshot several of these problems at work. they are almost always a capacitor. typicaly its one of the ones inside your power supply. if you have a spare one plug it in and see if the problems goes away. if not maybe disconnect the power supply from everything. assuming this is an atx power supply you can turn it on by shorting the green wire and any black wire togeather. both are located on the big P1 connector. i think youll find your problem is power supply.
- Curse not thine evil fate
I'm on the computer right now. I started to see how it acts. The sound came on, and it only lasted 1 minute.
Ok, so I did the test & it's the psu. rep to everyone who helped.
