This is the first time I have done anything to my computer. I got tired of looking at my really ugly dimension
So I went over to walmart and got some spray paint and the end result came out not that bad.
I forgot to take a pic of it but I have 2 drives and I painted the trays white(looks cool btw)
I painted the harddrive enclosure, cd and dvd drives, cpu fan duct, part of the power unit(I couldn't take off all of the components because I stripped a screw taking it apart), than those covers at the bottom left
I wanted to paint the inside and back white but I couldn't take the mobo off because I would of have to have taken the heat sink off to access some screws but I didn't have any of that paste stuff.
and you can see those covers here, I wish I could of painted the back of that power unit and could of painted the back side white.
so what do you think?
oh and does anyone know of any way/type of paint that is more durable than spray paint? for instance I put on 2 coats of primer and 2 coats of metallic blue on the cd n dvd drives and it just got scraped off putting it into the bay. I didn't put any clear coat on, would that make it more durable?
