Page 1 of 8 123456 ... LastLast
Results 1 to 10 of 76
Thread: Watercooling advice needed.
    Jan 2006
    Normal
    Default Watercooling advice needed.
    I have recently pruchased everything I need to set up a watercooling system (Thanks Paul!). My question is this: With a loop cooling two ATI 1900's and the CPU, would I need more than one rad (80mm I think)?
    . Spawn-Inc's Avatar
    Feb 2007
    Default Re: Watercooling advice needed.
    i have no physical experience on water cooling but from what i learned i would say no. for my setup, once i get it, its gonna cool 8800GTX, and a CPU with a thermochill 120.3.
    Sound: Logtiech Z 5500
    May 2005
    MO
    You might run a little hot in a dual gpu and cpu setup, but it shouldn't be anything horrific if you don't do massive OC & have a decent fan. I would suggest a 120mm rad at least, possibly 2x120 for that setup.
    Chester UK
    I would agree a dual 120 rad would be the best option but if you havent got room you could try fitting 2 seperate 120 rads.
    CAN YOU WIN PLAYER OF THE WEEK!!!
    http://steamcommunity.com/groups/tbcs
    Overclocked
    Apr 2007
    id also put the rads like this, rad, pump, cpu, gpu, rad, gpu,and back, or for better consistency on both cards,rad pump cpu rad gpu gpu back
    "Two people can keep a secret only if one is dead." Abraham Lincoln
    Balhannah, South Australia
    I'm going to be using a single 120mm and a 80mm radiator to cool my C2D E6600 and ASUS 8800GTX.
    Project: Elegant-Li *NEW*
    Project: Alpha FINISHED
    Jan 2006
    Normal
    Okay, thanks for the tips!
    No problem we're here to help.
    Case Modding MoFo Crimson Sky's Avatar
    Jan 2001
    Brooklyn, New York
    Like I told ya in the PM (this is more for the others), that radiator is a Dual Pass 120mm, much more efficient than say a single pass 120mm--it cools off a larger quantity of water at once, since the water stays in it longer.
    Jan 2001
    Brooklyn, New York
    If you can fit it, get yourself a 120mm fan shroud. This helps remove the "shadow" air flow area caused by the stator rotor (center hub) of the fan by giving it a little distance from the rad, and causing more turbulence.
