Lol
Lol
took me a while to figure out... then I realized I forgot to move the jumper
After that everything went smoothly. Thanks for the tip on the trial program. Worked great.
I did get one error during the copy...
"Unable to read disk 1 sector 16513786"
I'd assume that's the part that died in the old HD but could this mess up anything since Apparently I didn't get that part of data. Everything seems to be running smoothly and faster.
ihfsiouv less than an hour later.......
You guessed it...
Computer shut off. What could it possibly be???
I was looking at the mb and next to the heatsink, a line of those cylinder deals had dried/burnt looking stuff on the tops of them.
Can some1 recommend me a mb that is compatible. I hate to bother any of you but just posting this with the ss and all took 2 tries.
That is NOT good!
finally... shut down 4 times before i could post the pictures. The computer is completely stock and no attempts to OC.
My pc specs
Sorry about multiple posts guys, this pos just keeps shutting down on me and it gets really old typing everything thing out then it shutting down.
Are the tops bulging? It looks like some are.
If they are, you have capacitor failure, and that is 90% likely to be causing your problem.
Are you good with a soldering gun/iron? If you are, you can replace them. If not, better plan for a new mobo.
