Results 1 to 10 of 12
Thread: LED light out
    Jul 2005
    Default LED light out
    Hey all...I just noticed that the LED on the front door to my case went out. Is there a semi-easy fix? Or should I just pretend it doesn't exist?
    It's a Fudin ATX868WBP
    Thanks....
    Water Cooled
    Default Re: LED light out
    you can replace the if it burned out, but it might be the header that slipped off.
    Jun 2005
    Pittsburgh, PA
    LED's cant burn out unless the people who made them suck.
    ATX Mental Case temmink's Avatar
    May 2005
    Canberra, Australia
    Talking Re: LED light out
    Quote Originally Posted by timmer
    Surprisingly the quality of LED's has very little to do with the sexual orientation of the manufacturer, however I'd say that anyone sucking on an LED would likely cause it to fail if not 'Burn out' as stated. If, however, the inferance is that the manufacturer can suck anywhere, even physically removed from the LED itself, and cause said LED to burn out is a tenuous one at best. It's an interesting theory though.
    Replace it with another one.
    Asking if computers can think is like asking if submarines can swim.
    Asking if people think is like asking if a pebble has a preference between Beethoven and Mozart.
    temmink.org recondelta.com
    Overclocked Xbrid's Avatar
    Gold Coast , Australia
    u r either Seriously weird or serious funny. i can't decide
    "Hey look, the topic!! It's getting away! Quick catch it! *running* Must *running more* get on *panting* TOP...IC!!!! *collapses* "-Temmink
    Intel Q9450 @ 3.2GHz
    Asus P5E3 Premium WiFi
    OCZ Platinum PC3-12800 1600Mhz XTC 4Gb 7-7-7-24
    2 x Powercolor HD4870 512Mb in Crossfire
    Thermalright Ultra-120 Extreme with Noctua 120mm 1300RPM Pressure Optimised Fan
    Windows Vista Ultimate 64bit w/ SP1
    Case Wizard
    If you were just in the case check the headers. LED can burn out if to much power is put through them. Other wise they would just be slapping them in anyware.
    Hampshire, UK
    Quote Originally Posted by Malatory
    Wrong, LEDs can burn out if too much voltage is put through it. There is a difference between Power and Voltage. But LEDs will eventually be come dull over time.
    Quote Originally Posted by Xbrid
    He is seriously wierd but he thinks he is seriously funny
    There is no other choice.
    Jul 2005
    Thanks for all the lovely replies! But as you can see, I am posting in the 'Rookie' section...I have no idea what a 'header' is...? I tried unscrewing the housing where the lights are and for fear of breaking the darn thing, stopped at that point...
    I don't think it is a voltage problem...the whole thing is about 2 years old..
    If you aren't sure what case I am talking about, here's a link to a similar one...
    http://www.outpost.com/product/3850927
    Hopefully it is still active when you look...
    You guys are all probably saying to yourselves...'Darn newbies always bothering us with petty questions...!!'
    Thanks again....
    Dude...totally!
    May 2005
    Chico, CA
    my friend had the same problem recently. if this is a similar situation, its not the hdd led or the power led, its a cosmetic led that is prolly connected to a 4 pin molex somewhere. if thats the case, youll prolly have to open up the front panel that houses the led and see whats wrong. im guessing theres a broken wire somewhere. did it just suddenly die or did it get dim or flicker first.
    Jul 2005
    I just noticed it went out kind of suddenly...? I am hoping it's not the wires that connect from the door to inside the computer....I could see how they could get pinched or bent everytime the door is opened and closed....
    I am not exactly certain if I can just pop out the 'Z' emblem disc and see how it ticks, or if it's all glued and junk...?
    I feel like such a geek, getting all fussy over a silly little light....
  1. LED - Neon lights
    By dpilon in forum Modding Q&A
    Last Post: 08-14-2006, 10:01 PM
  2. Another LED Thread...
    By Cool1Net6 in forum Motherboards, Processors, & Power Supplies
    Last Post: 07-22-2006, 04:32 AM
  3. LED Mouse Light
    By abbtech in forum Motherboards, Processors, & Power Supplies
    Last Post: 06-29-2006, 04:23 PM
  4. Noob problem with LED in Circuit.
    By niietzshe in forum The Rookie's Nook
    Last Post: 06-16-2006, 07:54 PM
  5. Custom Case Power Controls
    By 427 in forum Modding Q&A
    Last Post: 04-13-2005, 02:53 AM
