Ok all I'm posting some pics of one of my first case mods. Blue leader was made along time ago ....2000-2001,but is still used as my primary gaming rig LAN PARTIES BABY!! So keep in mind that allot of the neat parts we have now were not available!
Specs:
AMD Athlon XP+ 2500 (OCed to 2700)
1Gig Corsair Mem w LEDs
EVGA Geforce FX5200 w 256Mb ram
Sound Blaster Audiology Platinum
80Gb Seagate 7200 HDD
120 Gb Seagate 7200rpm HDD
40Gb Maxtor 7200rpm Hdd
Plextor CDR burner
I/O magic DVD burner
DVD ROM
Media one bay
The Wires are a bit messy I know...I've been doing allot of HDD recovery for peeps lately and I'm to lazy to neat'n it all back up...but I will. The Window was cut out with a jig saw and edges cleaned up (very little) with a Dremel.
There is also a white strobe light inside the case, but it didn't show here.
The Logo is Vinyl hand cut by me!
The blow hole....Yea I drilled each one of them out by hand..(on a drill press)
The bottom pci cover plate is my fan and light controls Right is on, left is off. They don't get bumped @ Lanparties here!
The one thing missing in these pics is the 3 foot tall boom that hooks to the back of the pc, it's topped with a blue runway light (yes a real one) it also has a strobe light in it. It's not on cause it's hard to fit under my desk with it on. I'll see if I can't get some pics of it up some time.
Just so you can see some of what I've done...
Thanks for stopping by!
Crazybillybob
For a bit Of Trivia.....
What is the Symbol that is cut out of the side of this case?....Post your best guesses!!
Link To Original Thread
