I have 4 L.E.D.s hooked up to a power supply. Now I have some Blue L.E.D. Fans to for the center. But as far as putting led's all around the inside of the glass, Im in the dark.. . as In. . I dont know how. I've blown several of them up.
And Easy solution where I could hook up to the PSU would be Ideal.
Take a look and see if you can come up with an easy solution to my problem.
Sad I know. My First Case MOD.
Ignore the holes I will just fill them in and sand it all before I paint it.
