My Dremel should be delivered by Wednesday, so I can finally start making projects around here.
I've been given a sound proof piece of acrylic
Here's my crrent subwoofer
I'll need to get a bigger bit for my drill, to make a hole like this for the speaker to go into.
I can take this tube out and use it as an air vent in the new one. Unless I can find an acrylic tube somewhere. Or I could just make a hole.
And I could either use the feet it already has, or get some acrylic ones. Maybed some lighted ones.
And here's the speaker itself.
I made some cardboard cutouts of each side of the subwoofer, to make sure I'd have enough acrylic. I removed a little bit from two of the pieces, to compensate for the thickness of the acrylic.
And of course, my cat always has to be a part of everything
I was thinking of putting some lights inside of it, perhaps some sound sensative cathodes. Though I have heard some bad things about those cold cathodes. I'm also not sure how I would hook up power to the lights either. I don't think I'd want to hook it directly into the power for the subwoofer. The subwoofer plugs into the back of one of my speakers. Though maybe it would work. Does anyone have any ideas on how I could hook up the lights?
