which block performs better on 1/2 inch tubing; the Danger Den TDX or the RDX?
"Hey look, the topic!! It's getting away! Quick catch it! *running* Must *running more* get on *panting* TOP...IC!!!! *collapses* "-Temmink
Intel Q9450 @ 3.2GHz
Asus P5E3 Premium WiFi
OCZ Platinum PC3-12800 1600Mhz XTC 4Gb 7-7-7-24
2 x Powercolor HD4870 512Mb in Crossfire
Thermalright Ultra-120 Extreme with Noctua 120mm 1300RPM Pressure Optimised Fan
Windows Vista Ultimate 64bit w/ SP1
look up some reviews and tests, i havent used any of them
BUT FRAKK?!?!?! You're watercooled! How can u not know
no offense Frakk, but if you dont know, why did you have to post it? lol
i posted so he would research it a little and not wait for your non-sense posts
i havent seen any reviews, but the rbx has 3 little pipe thingies and the other only has 2 if that affets performance idk
I researched this a lot and found the TDX to be better than the RBX. Which is why I bought a TDX, it is a very nice block. I would also recommend the nozzle kit for it as well.
The TDX is DD's current flagship block, the RBX is the old one. TDX is considered better.
