anyone know of some non crap water cooling systems from newegg that are pretty cheap, under 100?
What are you needing to cool?
Your best bet is the Thermaltake Silent Water.
Good luck.
btw, post this in "The Ice Box" next time. It's easier for me to keep track of it if its in the right area.
**Thanks mods.**
yeah i know but its worth a try
Well, if you go with that TT Silent Water, then at least if it doesn't work right you'll only be out 60 bucks. ...unless it ruins your system. But I'm pretty sure you can trust that kit... it has decent reviews at least.
I think you should answer DaJe's question first before we recommend something. Which is, what you want to water cool. For all I know, you may want to just cool the CPU. Or maybe you wanted to only cool the GPU. Which would make SnowFire's recommendation irrelevant. Also, it would help if you told us what CPU/GPU/other it exactly is. Like the socket type.
I've heard decent things about the TT Tidewater as well if your looking at GPU.
Problem Solved
eh well id probably only be doing my cpu, e6600 , since ive heard bad things about hooking up watercooling on 8800's
