Results 1 to 10 of 10
Thread: 3000+ Venice Overclocking
    Dude...totally!
    May 2005
    Chico, CA
    Default 3000+ Venice Overclocking
    All attempts at overclocking my new venice core have failed. ive gotten my fsb upto 220 but every time i try to run a game or benchmark with the fsb higher than 204 i get either a BSOD or my pc locks up completely. ive got a thermaltake silent boost with a smart fan on it cranked up so loud it souds like my computers gonna take flight. ive tried boosting the voltage, but that only yields higher temps and an even less stable OC. Im running dual sticks of patriot ram on an abit AV8, and i know what your thinking, its my ram thats preventing my oc, but i know thats not the case. ive overclocked the ram in my other system just fine. Any input would be much appriciated.
    Water Cooled
    Default Re: 3000+ Venice Overclocking
    it might be the motherboard. u say the ram did good in an other system, and the cpu is new, the mobo might not take the extra mhz's
    The SlackMeister
    Brooklyn
    probly your mobo or RAM are holding you back.
    You might have the ealier version of the Abit AV8, Rev 1.0. If you contact Abit, they'll RMA your old board and give you the new Rev. 1.1.
    Also, search up "av8 overclock" on the Anandtech forums and you'll find a bunch of topics.
    http://forums.anandtech.com/search.aspx
    Dude...totally!
    May 2005
    Chico, CA
    I fianlly got a stable OC by lowering my LDT Bus Frequency...whatever that is. Thanks go out to reddog for suggesting the Anandtech forums. Ive managed to get upto 250 fsb with no problems. Making my 3000+, which runs at 1800mhz stock, run at 2250mhz with no noticable temp changes.
    Water Cooled
    Arizona, USA
    now I want to know what LDT freq is
    - Unknown
    Water Cooled
    LDT - An interconnection standard introduced by AMD that allows for fast data transfers among the Northbridge part of a chipset, the PCI bus(es), and the Southbridge part. In a multiprocessing machine the LDT bus can transfer data between sets of two processors. AMD now calls this technology HyperTransport.
    I was suspecting it to be the HTT too
    Overclocked
    May 2005
    Where ever you wish you could live.
    Quote Originally Posted by Frakk
    Obviously, that motherboad is an old revision. Anyways, I had a problem overclocking my brother's CelyD. I later found out it was the cheap OEM ram with bad timings that held it back.
    - AMD Athlon64 3200+@2.2Ghz | Gigabyte K8NSC-939 nForce3 250Gb | ASUS 6600GT 256MB |1GB Kingston ValueRAM
    Overclocked Xbrid's Avatar
    Gold Coast , Australia
    what sort of overclock would you expect to get with dangerden watercooling and venice 3000?
    Water Cooled
    as always, it is impossible to tell what overclock you are gonna get. you might catch a good batch and get a nice oc, or a worse batch which wont overclock that good. it also depends on your memory and motherboard a great deal.
  1. Overclocking celeron d processor
    By vermillion_part2 in forum Motherboards, Processors, & Power Supplies
    Last Post: 01-07-2007, 08:22 AM
  2. Overclocking with AMD 4200+
    By zitwep10 in forum Motherboards, Processors, & Power Supplies
    Last Post: 12-26-2006, 06:44 PM
  3. Bad Overclocking Colors
    By Indybird in forum Motherboards, Processors, & Power Supplies
    Last Post: 12-09-2006, 12:14 AM
  4. need help overclocking my video card
    By ForceFedFlesh in forum Video Cards, Monitors, & Cameras
    Last Post: 05-02-2006, 07:24 PM
  5. 2 must have noob overclocking programs
    By public_eyesore in forum Motherboards, Processors, & Power Supplies
    Last Post: 03-14-2005, 09:18 PM
