Facts:
The Thermaltake Blue Orb II is a CPU Cooler that works off of a three pin fan connection. Almost every motherboard is accommodated with at least one three pin fan header. This of course, as I now understand it, is not to be confused with just any three pin header you see on your motherboard.
Problem(s):
I'm an idiot. I have a Thermaltake Blue Orb II. My motherboard is made by dell. It doesn't have a three pin fan header. It has a five pin fan header. Square blocks don't fit into round holes. I dropped out in the third grade.
Solution:
Well I'm open to suggestions.
Things to be happy about:
Step one of my mod is completed (paint the skeletal frame black). I have a brand new Seagate 320GB HDD. I finally have a LGA775 CPU Cooler. My hands are covered in Arctic Silver Thermal Grease and I have black spray paint all over me.
On a side note:
It's good to be back, if only for a few minutes. But like all good things do, they have to end. ...well then again, I could always just beat up my little brother and steal his computer!
See you guys in a few!
