Results 1 to 10 of 14
Thread: slowest PC problem ever
    Dude...totally!
    May 2005
    Chico, CA
    Default slowest PC problem ever
    Ok, so i replace my aging PSU with a new one and suddenly i cannot, for the life of me, understand what happened while swapping it out.
    Now when i start my PC, the ram check takes about 20 alone, 5-10 times longer than it should. it takes equally elongated periods of time to get it to find my hard drives, yet it always finds them. the BIOS is the only, thing software-wise, i could get to run, and it seems to run fine, considering its justwhite on a blue screen. ><
    can anyone think of what could have gone wrong here? why would it work, but only work at ~1/8 the speed? and more so, why would it stop working after i just swapped out PSUs?
    Thanks in advance for any help.
    Case Modding MoFo Crimson Sky's Avatar
    Jan 2001
    Brooklyn, New York
    Default Re: slowest PC problem ever
    does the PSU have automatic switching between 220 and 110 volt? Or is there a switch on the back? Check the obvious stuff first. Make sure you unplug every device on the PSU and reseat it. Make sure the 12v 4-pin line for the processor is seated. just some thoughts. what brand/model is the PSU?? give us some sys specs.
    Feb 2007
    Peterborough, Ont.
    check with a multitester to make sure you are getting the right voltages out of your psu.
    i have had inumerable problems from ****ty PSU's
    i am the "starving artist" of the modding world
    That's classified.
    I'm actually having this same problem too. Yesterday I was cleaning an old PII* PC & PSU (9 years old) and now it takes almost 5 minutes to count the RAM (512mb).
    I'll try unplugging everything as Crimson said and see if that fixes it.
    *Pentium II 550mhz
    Nov 2005
    Scotland, UK (NOT England)
    You might just turn on the fast boot mode, which skips the ram test there Redundant.
    -Dave
    That's classified.
    -Dave
    OK, I changed SCAN USER FLASH AREA to ENABLED and it seems to have made it _slightly_ faster (it could be my imagination) but not "as" fast of a start up of the BIOS as before it was cleaned.
    EDIT: Do you think I could have screwed something up while taking it apart because I didn't change anything in the BIOS yesterday that would have made a difference. (In case it would help, I took out the PSU too and unplugged everything except the Proc. and modem (which was in a very odd looking slot))
    Nov 2005
    You can disable the RAM check. It's not usually necessary on todays modern PC's. It's from a time when RAM was so expensive that they delivered in Armoured Trucks, and you wouldn't replace a stick if it developed a fault.
    -Dave
    Nov 2006
    Montréal
    Quote Originally Posted by Redundant View Post
    Not necessary, you said it is an old computer, maybe it's just time for a battery check
    Feb 2007
    although this sounds obvious: is the PSU rated to the power demands of your pc?
    That's classified.
    Quote Originally Posted by slytherock View Post
    What exactly does the battery do anyways?
    Quote Originally Posted by viper View Post
    Yes, this is the stock PSU it came with.
    Also, I hope I'm not hijacking AKA_RA's thread. *hands keyboard over to AKA_RA*
