Mitternacht
A new member and friend of mine, Jonny Axehandle, has been describing his build to me. It all sounds good, except his PSU might not be enough. His 12-volt rail puts out 21 amps. The card uses a recommended 38 amps.
Will his PSU be enough for now, until he can get one with 38+A?
I also found a power supply with 3 12-volt rails, 19A each. Now, if you use a PCI-E connector from two of the rails, will the amperage combine to give him the recommended 38 amps he needs for the X1950?
