Sorry I meant the radiator not the pump lol. I was going to put the probe in the rad to auto adjust the fan sped. Would the rad be hottest at the inlet or dose the copper dispurse the heat?
I don't think you will have to worry about it. But if you really want to, wait until you get the rads and then feel out where the hottest spots are. That is where I would put a thermo stick if I ever wanted to do that.
Sorry , I have been away for a few days. I guess I'll just wate and see how the temps go before I do anything. I have the fan attached to my GPU with the thermal probe and It seems to do a good job.
Oh, and I decided to go with the D4 pump instead of the mag or the D5. I would use the other one you listed before but it is kinda awkward to mount.
I havn't got it yet but the site i'm getting my stuff from still lists it, they still have stock. If not i'll just get the D5
I was just wondering, is there any set inlet/outlets for rads and water block or can you just use either or?
No for rads.
Yes/No for water blocks. It depends what water block you have. Some are symetrical so it works. But others aren't, like the Swiftech Storm.
I know about the DD RBX block cos it has the 2 outlets and one inlet but what about a DD 8800GTX block or a northbridge block?
What northbridge block are you getting?
