I was just wondering, do Danger Den make any 8800GTS water blocks yet? or do they make and that are compatiable?
Aren't the GTS and GTX the same in layout? If thats true, then yes.
I thought because the GTX was longer it had different mounting holes and wouldn't fit. I dont want to spend $850 on two GPU's and another $450 on water blocks. There must be a cheeper alternative. One that only cools the GPU and not all the other hot spots that the GTX block states.
Make your own blocks if you really want to cut prices.
Why do things the difficult way? You are talking about this waterblock from Danger Den right?
http://www.dangerden.com/store/produ...&cat=48&page=1
Well, according to their site, it is ONLY for the 8800 GTX.
I thought that aswell about how it states 8800GTX water block. Well i guess I will just send them ans email and find out.
I just wont worry about it. I was thinking of going SLI with two 8800GTS 320MB versions but then I will need a new PSU. I will just stay with the GTX and my previous water cooling setup.
