Results 1 to 5 of 5
Thread: Cooler Master Centurion 532
    Jan 2007
    Distant land of SERBIA
    Default Cooler Master Centurion 532
    This is a great case for modding. Not so expensive, but not cheap either. I have this case right now, and soon I will start modding it. I will let you know about my progress, and post you some pics.
    A proud member of the 1st Serbian Modding organisation :: CASE - freaks ::
    Visit our modest web page: CASE - freaks
    Dec 2006
    Reno, NV
    Default Re: Cooler Master Centurion 532
    Yes.
    This case is designed for good airflow, so however you end up modding it, make sure you dont disrupt the current. good luck!
    Jan 2007
    It has one 120 x 120 mm cooler in front (blue), I will put 120 x 120 Cooler Master cooler (green) on the back, instead of my intel core 2 duo box cooler, I'll put CM Mars, and I will put PLEX on 1 side, with some fine laser etching, and green LED to bring the etched design into it's place. I will put pics here when I'm done
    Chester UK
    I like your style dude i had that case with the blue fan first thing i did was put a green fan on the back mount
    CAN YOU WIN PLAYER OF THE WEEK!!!
    http://steamcommunity.com/groups/tbcs
    Jan 2007
    Was it awsome???
