Results 1 to 7 of 7
Thread: Laser cutter for plexi etching?
    Alabama
    Default Laser cutter for plexi etching?
    I have access to a laser cutter which would be alot easier and faster to make an etching... would if obtain a good effect for LED lighting in the plexi?
    Nov 2005
    Scotland, UK (NOT England)
    Default Re: Laser cutter for plexi etching?
    I think Crimson Sky used a laser-etched window in Project Mars city (Doom 3) with great LED effects.
    I don't know if you can use a laser cutter to etch, but someone else around here will.
    -Dave
    My school has a laser cutter. the nicest and most convient tool ever. you should be able to etch your plexi perfectly fine, but sometimes some types of plexy glass dont work really great because it because it becomes discolored and all charred up. the best stuff ive used is frosted plexy.
    Sep 2005
    Doylestown, PA, United States
    Yes, a laser engraver should work to etch acrylic. The only catch is make sure it is actually acrylic, not polycarbonate, PET, etc. Commonly people call any clear plastic "plexiglass" when really plexiglass is a brand name of acrylic (polymethyl methacrylate).
    Typo:
    Oct 2008
    Retrosmith Mach's Avatar
    Texas
    Hi Mattman, check out this thread for another possibility.
    http://www.austinmodders.com/modules...ewtopic&t=2194
    Jun 2008
    MA
    thanks for the link!
  1. Laser etching
    By SgtM in forum Idea Zone
    Last Post: 08-16-2007, 03:34 AM
  2. Custom laser cut case windows
    By Sotacs in forum Modding Q&A
    Last Post: 11-01-2005, 05:23 PM
  3. Rookies looking for customer laser etching services.
    By revlimit in forum The Rookie's Nook
    Last Post: 10-05-2005, 10:29 AM
  4. Looking for someone to do a custom laser etched panel.
    By Kn1ghtl0rd in forum The Trading Post
    Last Post: 08-09-2005, 08:04 AM
  5. My first etching
    By ludothegreat in forum Your Mods
    Last Post: 05-13-2005, 12:11 PM
