Hey, does anyone here use the XP-90 heatsink?
I was going to put at Gigabyte PCU21-VG heatsink on my CPU because I needed something that is not too tall as I am using it in a SFF pc.
The dimensions of this heatsink are:
8.5cm Width
9cm Depth
9.5cm Heighth
Thanks makes it about 2cm too tall and .25cm too wide
I need something a bit shorter. if possible.
I know there are sites out there that have the dimensions of the heatsink but I need to know if that is the height of the heatsink with or without the fan and if it is measuring just the heatsink or including the height off the mobo PCB. If anyone out there uses this heatsink can you please illuminate me?
Thanks
