Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Hola All.. 1st build question
    Default Hola All.. 1st build question
    what is a good gaming case that will accomadate 2 dx10 cards and 1000w PSU.
    Main things I am look for in a case for my 1st build is ...
    1.) good instructions
    2.) room to work
    3.) solid case that will last me a long while maybe aluminum?
    thats all i really know to ask for at this point...
    I just want my first build to go smooth and reading a lot of reviews on newegg leads me to believe some cases can cuase major frustration to 1st timers ... then the sheeer volume of cases to choose from is overwhelming
    Sep 2005
    Doylestown, PA, United States
    Default Re: Hola All.. 1st build question
    First off.... why do you need a 1000 watt PSU?
    What kind of system will you be running? Will you want to mod it later? What is your budget?
    Also, what do you mean instructions? Cases are pretty straight forward... you put stuff in them.
    Typo:
    Reasons / answers to yor questions in red
    Quote Originally Posted by tybrenis View Post
    well i assumed to run 2 dx 10 graphic cards later i would need a minimum of 850 .. maybe not /shrug
    a top notch gaming rig is what i want to build
    Will you want to mod it later? doubtful i will do more than put the componets in the case
    What is your budget? i dont really have one in mind for just a case but want to stay between 3-5k on the computer i build
    reading some reviews on new egg abot various cases i would notice people say things like this case would not be a good case for a newb , or not a lot of instructions for new builders .. etc or the opposite of that saying this was decent for a begining 1st time build lots of good directions etc.. or even how some cases need to be dremmeled to fit componets or hard to work in from lack of room ... thats what i was referring to
    Resident Alcoholic
    Nov 2005
    Chichester, England, uk (NOT Scotland)
    The Nvidia 8 series cards use two pci-e power inputs; I expect that it would take a ridiculous amount of power to run both of them safely and efficiently!
    As for a case, it depends what style you're looking for. I personaly would go for either the lian li v1000+ or my current case, the NZXT Lexa which is very spacy , comes with some nice added extras like a carrying harness, has an awesome brushed aluminium front bezel, LCD temp. display, and most importantly, a 120mm fan in the window, over the graphics card slots instead of the cpu, so it blasts cold air onto your graphics cards!
    http://www.newegg.com/Product/Produc...82E16811146018
    H
    Sep 2005
    You can't go wrong with a Lian-Li, they make great cases. Have you looked into any of them? They have some sleek designs with tons of great features etc. Also, for ease of install and whatnot, I wouldn't worry about it too much - it's all pretty straight forward and if you have any trouble that what these forums are for!
    Typo:
    Nov 2006
    Montréal
    You can also look for
    TT Armor
    CM Staker
    Silverstone
    All of them are good and big cases
    Case Wizard
    California, USA
    Quote Originally Posted by onelegout View Post
    H
    I think the 8800GTX has 2 PCI power connectors is to insure stability. So lets say... instead of sending 40A through one power connector, they send 20A on two. They are the most power hungry cards, but it isn't ridiculous.
    I personally like Silverstone caes. They just came out with the TJ09, which has a 120 mm fan to cool your video cards.
    Review by Hexus.net
    Imma computer! isunktheship's Avatar
    San Diego
    Jesus, 3-5k... that compy is gonna be amazing.
    Lian-Li's are pretty great cases.
    Are you going to go watercooling?
    Quote Originally Posted by isunktheship View Post
    Id love to go water cooling and over clock but heh ive never built me 1st comp yet and scared of water cooling -- how hard is it?
    May 2005
    MO
    Watercooling can be a major hassle the first couple of times you use it or troubleshoot it. Broken seals, leaks, There is not only increased costs, but maintenance and monitoring.
    I'm not trying to dissuade you, just giving you the info I was never told.
    If this is your first build ever, avoid watercooling. Get the basics down a few (dozen) times, then go for a more advanced setup.
    BTW, the computer I'm posting this on is a watercooled rig. I feel some pride in saying that. It took lots of work I wouldn't have had to do otherwise, but you can't argue with a 78F processor.
  1. question about new hard drive.
    By notochord in forum The Rookie's Nook
    Last Post: 08-25-2006, 12:48 AM
  2. Resistor Question..
    By Vinny_D in forum Modding Q&A
    Last Post: 07-20-2006, 12:41 AM
  3. quick question Power Supply question
    By SoKewl in forum The Rookie's Nook
    Last Post: 06-24-2006, 02:57 AM
  4. question about my next SLI build
    By ForceFedFlesh in forum Video Cards, Monitors, & Cameras
    Last Post: 03-15-2006, 02:11 PM
  5. Places to get materials to build a case.
    By k2000k in forum The Rookie's Nook
    Last Post: 02-05-2006, 12:17 PM
