To start this Thread off, I apologize for the lack of pics because it's the result of the lack of camera . Hope some one finds this helpful.
Making your very own Bullets! (Prop style J)
By: Drac9998
After having read NovusProgMorbus turret case mod thread and progbuddy idea of making bullets, I decided to go down to the ol’ workshop and make 1. Here’s the process that I ended up using.
1. The Shell Casing: This was actually the easiest part that came to me. Taking a copper pipe half inch (1/2) diameter and measuring it to 3 inches in length and cutting it. Will give you the basic starting point for your bullet. To make the bottom piece where the charge is held I didn’t really go to fancy on this because I was trying to see if it would work, more important then being pretty for now.
You have two choices @ this point: 1 very long and 1 super short (guess which one I did before I figured this out)
a) Take a good 2 inches from the same pipe and cut it vertical so that you are able to see a “ U “ shape, take a pair of pliers and carefully start to bend it so that you are able to get it to a decent flatness, once you’ve got there take 2 pieces of wood (what you have on hand 2*4 etc just big enough to put the copper piece in between. Clamp the wood together or hold it with your hands just keep the wood from moving to a minimum, now take out your trusty hammer and start pounding that thing till it’s as flat as a supermodel. Take your compass and measure out a diameter just abit bigger then the pipe and draw it on the piece of copper you just pounded, and cut. This chunk should make 2-3 of these parts.
b) Take a penny, grind it sand it smooth.
Now to connect the two pieces you don’t have to be picky, its not structural just esthetic. You can solder weld it, super glue/ cement glue, whatever you want that will bond the two materials.
To add more detail for example the bevel usually seen on the bottom of bullets you can file it, mill it out etc before you attach the two pieces. Reference pic: http://www.special-warfare.net/data_..._bullet_01.jpg
2. The Bullet: The best material to use here really is a wooden dowel (getting the same size as the copper pipe is best) just as progbuddy mentioned. The shape is up to you; speared, hollow point etc. I just did a spear shape. Take 1 ½ off of your dowel, mark it at 1” from the top (important) this will give you the guide for sanding the shape out and leave you enough material to taper the end to place in your casing.
