Ok so Im new here but i've been moding cases and electronics for a while... I'm only 16 but I started at 10 thanks to my dad... I'm working on a Borg Cube case With an ABIT SL6 Mobo and two 40 gig hdds. I want to put my two Nvidia Gforce 4000MX video cards in with a TV tuner PCI card and a USB 2.0 PCI Card. It runs on a 1 GHZ pentium III and 3 PC133 256mb sdram. I know this is kinda out of date but it's cheaper then getting the latest stuff. But i need to find out what the best way of cooling it would be. Here's the upload on the research I found: A large amount of fans could put a load on the psu but if you balance it with a few fans with good rpm you could survive. Then there is the water cooled technique. But that can get expensive. and then there was an article on this new liquid that remains at a cold temp and does not carry electrical current, you can submerge your mobo and hdds in this liquid and it will not corode or damage any electronics. but again, that is really expensive. What should i do?
FireFoxConn a.k.a Evil Genis
