On a computer i'm working on i had an issue with xp pro which i routed back to the motherboard, after replacing motherboard and running repair on xp pro,
however when i go to login it crashes at the screen "applying personal settings"
sparse data from ya, but it could be a corrupt profile. try logging on as a different account and see if it crashes then.
i've tried logging in as my standard user and just as administrator
When logging in to administrator it simply says i need to activate windows with a prompt to do that now, click yes and it then logs me off.
WHat details do you need to know?
do you have the same probs in safe mode?
every mode, safe mode with or without networking, boot logup, all of them
Sounds to me like you need to remove your data and reload your OS. Much less time consuming than troubleshooting.
I would suggest trying boot logging and checking the logs in case it is just a failed service.
