Results 1 to 9 of 9
Thread: linux 3d cad software
    Overclocked
    Sep 2006
    Atlanta, GA
    Default linux 3d cad software
    anybody know of 3d-capable cad software for linux (specifically ubuntu...dapper at the moment, but might upgrade soon)?
    i've seen a couple websites that offer 2d, but i'd like something similar to google sketchup, which, unfortunately, doesn't seem to have a linux version available.
    Jun 2006
    In the Redwoods
    Default Re: linux 3d cad software
    Overclocked
    Sep 2006
    Atlanta, GA
    awesome, it's even available as an apt repository.
    i'll give it a shot tonight, thanks
    edit:
    bah. still having dependency problems from a friend's attempts to help me a week or two ago. i'll play with it after i manage to reinstall or upgrade to edgy.
    silly debian user thinking that ubuntu can use debian repositories
    edit again:
    sudo aptitude purge tzdata
    yay.
    got blender installed, can play with it tonight
    Jun 2006
    The Dairy State...
    Blender is very fun. I have it right now (Edgy and Windows) and I'm really liking it. Read the tutorials on deviantART, as they really helped me learn it.
    RIP Bucko
    Overclocked
    Sep 2006
    Atlanta, GA
    yeah, i started it up last night, and uh...it ran fine. i just stared at the interface for a bit and realized that i'm going to have to bump the screen res on the linux box down a bit. so much for being able to read small print from far away :p
    there's a wikibook that i'm gonna look through as well:
    http://en.wikibooks.org/wiki/Blender_3D:_Noob_to_Pro
    it seemed to be pretty damn all-inclusive
    all i *really* want to do is work on case and component dimensions - i think this is going to be horribly overkill but with a raytracer, i'll get to see how it'll be shadowed inside! silly :p
    mm deviantart, home of the best worksafe computer backgrounds
    Jun 2006
    The Dairy State...
    Yeah, I read the Noob to Pro too (not all of it) and it was very helpful as well.
    RIP Bucko
    Nov 2006
    Synergy is a mechanical CAD system with emphasis on CAM for driving CNC machines.
    We have the full system available for download for Linux at:
    http://www.webersys.com/linuxsynergy.htm
    The complete download is about 38 Mb.
    We have 8 formats built/tested:
    RPM format for Red Hat Linux release 9 (Shrike)
    RPM format for Mandrake Linux release 9.2 (FiveStar) for i586
    RPM format for Mandrake Linux release 10.0 (Community) for i586
    RPM format for SuSE 9.0
    RPM format for Novell 9.0
    RPM format for Slackware 10.0
    DEB format for Debian 3.1
    gzipped tar file
    The gzip format requires a few command lines to unpack.
    The RPM format makes for easier installation but is sensitive to minor library
    differences and can refuse to install.
    You are free to use the CAD portion of Synergy for an unlimited time.
    The CAM and Solid Modeling portions will require an access code.
    You can get a free 30 day trial access code by sending the ID and version number
    that appears in the dialog box that appears when you access those areas of the system.
    Or,
    You can force Synergy to display the information by typing:
    \Xaccess (Enter)
    in the input line.
    Overclocked
    Sep 2006
    Atlanta, GA
    i'm not sure if i should feel honored or what that somebody created an account solely to plug their software
    also, if you even bother reading, if you make available an apt source for ubuntu, i might try it. as it is, i don't feel like futzing around with building from source
    Jun 2006
    The Dairy State...
    Quote Originally Posted by ajmilton View Post
    The .deb package will work with minimal headaches...
    Edit: Or use Alien and the .rpm package.
    RIP Bucko
  1. Poster Software??
    By crazybillybob in forum Software
    Last Post: 06-05-2010, 11:29 PM
  2. I. Love. Linux.
    By tybrenis in forum The Chatterbox
    Last Post: 10-06-2006, 04:36 PM
  3. Linux Cube
    By NadeChaser in forum Works in progress
    Last Post: 07-27-2006, 12:55 AM
  4. Linux?
    By onelegout in forum Operating Systems
    Last Post: 05-31-2006, 10:04 AM
  5. Linux for n00bs...Q's I have
    By crazybillybob in forum Operating Systems
    Last Post: 12-13-2005, 06:04 PM
