I saw an idea I liked on either this or another modding site, I don't remember which one it was because this site is the best!
Anyway, you know the big flat grey cables? They took a sharp knife, cut between every 3 or 4 little wires, and then pulled them apart to make spaghetti. Then they bunched up the spaghetti, rolled it tight, and taped it with black electrical tape.
I tried it out on a couple of extra cables I had in the garage, and it worked out great... I think... It seems like they would be much easier to work with, easier to hide, etc...
Has or does anyone do this? Can it hurt, help, hinder, etc? Any pros or cons I should know about before I do this in a real computer?
