im doing my frist mod on an older case and it only has 3 hd slots and i want more. Should i just fab one or is there some place that i can buy one?
thanks
thanks
I've found that ripping a hard drive cage out of an old case works rather well.
If you want to make one for style purposes, go for it.
I don't know where you are from Monk, but in Maplin in the UK you can buy hard drive mounts and attach them to the original cage.
Or you could just suspend them from the cage above using elastic, preventing vibrations running through the case.
m4gnum.com/tardis/ - Doctor Who inspired case
