i wasn wondering what the least wattage a micro-atx mobo would need to run
most htpc's come equipped with a 430 Watt or a 320 Watt psu, and those are usually enough to handle the mobo, high end cpu, single DL DVD, multiple HD's, and a video/capture card.
the antec fusion comes with a 430 Watt PFC 24 pin antec psu, for example. A couple others I have seen use an enermax sfx form factor which is only 270 Watts.
I ran a 3.0 GHZ Celeron D off a 200 watt. I had lights and a bunch of **** hooked up.
Just PM me, I'll give you the 200 watt Micro ATX PSU for like $5 + Shipping.....Only used it once, Still shiny, works perfectley.
