Results 1 to 2 of 2
Thread: Temp. Sensor Replacement<--HELP PRO'S!!
    Question Temp. Sensor Replacement<--HELP PRO'S!!
    I have an X-Discovery Case and it has a temperature sensor inside of it. I broke the sensor on the end of the wire. I need a new one. What would be a suitable sub? It's a two wire sensor and the voltage is 3.38VDC. I tested it with a voltmeter. thanks.
    Dec 2005
    long island, ny
    Default Re: Temp. Sensor Replacement<--HELP PRO'S!!
    i have a case from that same company, whenever i needed replacements for certain things on my case i called them up and they shipped me wat i needed, of course i did have to pay
  1. Water temp
    By thephreak99 in forum PC Cases, Tools, & Cooling
    Last Post: 03-26-2006, 01:47 AM
  2. What's in a pro's shop?
    By X child in forum PC Cases, Tools, & Cooling
    Last Post: 08-15-2005, 12:44 PM
  3. CPU temp on LCD display
    By Malaktix in forum Motherboards, Processors, & Power Supplies
    Last Post: 06-24-2005, 11:04 AM
