Results 1 to 7 of 7
Thread: Need a hobby knive set?
    MitaPi
    Guest
    Default Need a hobby knive set?
    Cheap and every attatchment you could ever want on a hobby knife!
    http://www.hobbylinc.com/htm/hca/hcahcar0350.htm
    ...400
    Jun 2006
    Sydney, Australia
    Default Re: Need a hobby knive set?
    $15.19 at that price the blades in the set will porbably snap and wont hold there edge. Good find thoug
    Need a sig
    MitaPi
    Guest
    Yeah, Most likely. I only posted it so I could have my 400 posts ^_^ But I didnt want to post something completely useless. lol
    Jun 2006
    Sydney, Australia
    A. That's sad
    B. That breaks the forums rules
    Need a sig
    May 2005
    MO
    He's not breaking the forum rules by posting something someone might find useful.
    I have basically the same set. Works great for light wood work and foam. Haven't tried with anything else.
    MitaPi
    Guest
    Exactly my thought. I made sure I posted something that SOMEONE might find useful. lol not like that thread in hot hardware about the hot moms or whatever that was about.
    I work with alot of clay so I was actually thinking about buying it for that. Which you could also use on computer mods that use foam or clay or whatever stuff you use.
    Overclocked Guttenaffe's Avatar
    Ohio
    $3.75 http://www.allelectronics.com/cgi-bi...NIFE_KIT_.html
    owned
    (I have this set, the case is crap but the blades are GOOD and for 3.75 buy two or three.)
    -Gutte
    No, I'm not a compleate Idiot!
    Some parts are missing.
  1. TBCS Review: PolarFLO TT Series Chrome Basic System Set
    By Dante in forum Reviews / Previews
    Last Post: 04-01-2007, 06:59 PM
  2. watercooling set up
    By sirkillalot617 in forum The Rookie's Nook
    Last Post: 07-25-2006, 02:10 PM
  3. FS: Full Danger Den w/c set up for Athlon 64
    By TheGreatSatan in forum The Trading Post
    Last Post: 06-28-2005, 12:27 PM
