how would someone such as me make some thing like the lights on kitt in knight rider u know when the red light in front goes side to side
theres actually a circuit that you should be able to find on a mod site somewhere, totally forgot where, but i know its out there. so if you want it too look just like it, they show you the basic design of a circuit that does almost exactly what you want. i think the only part thats not true to the original look is that their design has no fading of the lights really, so youd have to find a circuit or make one yourself that did that part. if you can solder, you should be able to do this. if you cant solder, im sure you can learn.
Here is the kit for it but it's from an aussie store.
http://www.dse.com.au/cgi-bin/dse.st...uct/View/K3168
I' am sure you can find a copy of it in America.
Need a sig
can u ranslate the price to american $$$
Now All i needd is something that makes that noise every time it Scans side to side
A$22.94 = Us$17.51
Need a sig
That seems cheap enough
If you're handy with a soldering iron: http://www.bit-tech.net/article/82/. I guess that's the one AKA_RA was referring to.
m4gnum.com/tardis/ - Doctor Who inspired case
Well I think the original light fading from knight rider was due to the fact that they used normal car lights. If you turn a car light off, it will still glow for a fraction of a second, thus creating an afterglow effect with the knight rider light...
