How do you guys mod guitar cables to work as computer cables????
I mean make acomputer cable look like one
You don't.
Sry about my stupidness
One idea would be to sleeve the bare wire into a clear tube. Assuming the wire was aluminum it would _look_ similar to a guitar wire.
not wire like the strings you actually play with on a guitar but like the cable u connect from the guitar to the amp
Yes why on earth would you need that wire hooked up no a computer. At radiosack you can fidn adapters that take ar egular speaker wire and make it big as the amp wire.
Thats even easier then. Do like Razor suggested...Originally Posted by NamesAreUseless
Do you mean like a guitar jack lead socket thing Namesareuseless? Like this photo: http://www.maplin.co.uk/images/full/1282i0.jpg
If so, I've go no idea.
m4gnum.com/tardis/ - Doctor Who inspired case
Wait, do you just want it to look like a guitar cable, like just plastic black sleeving? Like not have the individual wires from your PSU visible, have them all in one black casing?
RIP Bucko
IM talkin about wat m4gnum said
