Alright, so I'm completely new to case modding, but not computers in general. For my current computer I need to basically build a case from scratch. I can't find a case nearly big enough for my needs and the current CM stacker just isn't working out.
I really need some help on the idea side, as all my parts are just flat out huge.
Inside will be:
Tyan Thunder K8WE (huge motherboard)
PC Power and Cooling 850 SSI (monster PSU)
4x 5 1/4 bay devices (dvd, fan controller, removable hd tray, graphics card PSU)
Pair of 7800gtx's
Triple 120mm fan radiator from Danger Den, and the biggest pump they have available http://www.dangerdenstore.com/produc...&cat=84&page=1
I think that covers it for all the big stuff, my major problems are making the psu and radiator fit tidy, with room for the hoses/pump and resevoir.
So if any one wants to help me get started it would be much appreciated. BTW I'm looking to make a tower case, maybe at max 5 inches taller than a stacker (with it's casters).
Also no 3 1/4 drive bays are needed, my removable handles my hard drive needs.
