Results 1 to 10 of 10
Thread: Custom "Racing" Fan Speed Control?
    Default Custom "Racing" Fan Speed Control?
    So I was in the autoparts store picking up some sandpapers and rubbing compounds for my first real mod, (starting with a practice case, working to get a nice mirror'd paint job), and I spotted something that gave me an idea.
    I saw one of these custom gas pedals; http://store.barefootcentral.com/Pro...RBFMGASCVR.gif
    And I thought to myself, wouldn't it be funny to have a "racing" theme'd case, and wire your fan speed control to a mock gas pedal on the floor. Push the pedal down, increase the fan speed. Possibly even be able to set a "cruise control". This way you could actually "rev" your case.
    I'm assuming this is possible, but at the moment my knowledge of electronics and controllers is a bit lacking. Anyone know where I should start looking to make this happen?
    Nov 2005
    Scotland, UK (NOT England)
    Default Re: Custom "Racing" Fan Speed Control?
    HAha...revving your case. Sounds cool. Pretty simple, easily done.
    -Dave
    ComputerKing
    Guest
    man this will be funny Thing ! Go head and bush lol this thing lik car gas swich !!
    Lol Good luck
    Razors Edge
    Guest
    I bet you that paul capello can do it
    Practice random acts of generosity Omega's Avatar
    Feb 2006
    A house
    Quote Originally Posted by Razors Edge
    I bet you that anybody with some electronics skill and knowledge of how all the components works can do it.
    =p
    that probably includes paul, though.
    I'll have to set it aside for my 2nd case. I know it should be easy, I just have to holler @ some of my Electrical Engineering buddies to give me a circuits refresher.
    Blunt Master 5000 CanaBalistic's Avatar
    British Columbia, Canada
    The best thing to use would be a slider switch from an older tape player or somthing. All's you'd have to do is hook up a small linkage from the pedal to the switch.
    You Dont Spread Democracy Through The Barrel Of A Gun.
    That's classified.
    What about using a foot pedal from a sewing machine?
    MitaPi
    Guest
    lol HA! Thats a great idea, I just dont know how you people think of these things. I guess maybe if I used my creative side of my brain for half a second..? :p
    Razors Edge
    Guest
    KK, I have done a bit of research.
    Go to thermaltake.com and check out the Smart Case FAN. It comes with a controller then can speed it up or slow it down. You simply have to screw around with the cables and the pedal cables, it can easily be done.
  1. fan control switch question
    By Rabidsquirrel314 in forum Idea Zone
    Last Post: 04-08-2006, 06:59 PM
  2. fan speed mod
    By richmandudeus in forum The Rookie's Nook
    Last Post: 12-11-2005, 12:02 AM
  3. Fan speed switches.
    By joman2055 in forum The Chatterbox
    Last Post: 08-13-2005, 12:12 AM
  4. custom fan grills
    By TacomaTRD in forum The Rookie's Nook
    Last Post: 07-14-2005, 01:19 PM
