Can anyone tell me if I have everything I need to have a beginners water cooling kit? I'm making my own reservoir out of UV Acrylic. (which you can find in a link at the bottom of the page). Anywho, I'm just building a low cost, bare essentials kit so if I am missing something that is important then please let me know! Otherwise just tell me if I have everything or not. ^_^ .....also on some of the items, I dont know how much of it to order. So if someone could tell me... that would be truly awesome!!!
-Thermaltake Volcanoe 4005 Heat Exchanger
http://www.xoxide.com/thermaltake-vo...exchanger.html
-Swiftech 1/2 Water Pump
http://www.xoxide.com/swiftech-mcp655.html
-Thermaltake 12cm Big Radiator (Just because it fits into the 120mm spot)
http://www.xoxide.com/thermaltake-12...-radiator.html
-Primoflex 1/2'' UV Blue Tubing
http://www.xoxide.com/primoflex-12id-34od-uvblue.html
-Primoflex 3/8'' UV Blue Tubing
http://www.xoxide.com/primoflex-38id-58od-uvblue.html
-1/2'' to 3/8''th reducer
http://www.xoxide.com/bl1to3re.html
-1/2'' System Clamps
http://www.xoxide.com/5sncl1sy.html
-3/8'' System Clamps
http://www.xoxide.com/1sncl3sy.html
-Danger Den Fill Ports
http://www.xoxide.com/danger-den-fillport-black.html
-Promo Chill 32oz. Pre Mixed Coolant
http://www.xoxide.com/primoice-nonco...id-uvblue.html
My Acrylic Reservoir....
http://www.thebestcasescenario.com/f...8605#post38605
Edit: I am now going with the danger den pump... half the price and it does what I want.
http://www.dangerdenstore.com/produc...0&cat=4&page=1
