i have come acrossed 3 airconditioner radiators and was wondering if any one would know how they stood up against any of the standard liquid cooling radiators
*3.4ghz P4 w/HT
*radeon 9800pro
*audigy2 pro
*maxtor 200gb HD
I think we'll need to know which specific radiators in question you mean...
-Dave
give us some dimensions, the material you every thing that could give us an idea about the surface aria
LOUD AND PROUD !
i found that one of the radiators is useless due to oxidation on the fins and copper tubing...
but here are the dims...
#1
10" x 8.5" x 3" there are 34 pipes in the radiator, avg diameter is 3/8 inch
#2
18" x 9" x 2" 26 pipes w\ avg diameter of 3/8 inch
the radiator has aluminum fins and copper tubing through-out
both have mounting brackets on them
#2 should make a sweet rad in an W/C setup
some pics if you will....
LOUD AND PROUD !
Yes, pictures would be wonderful!
check out the radiators at TV MCe
my num. 2 radiator looks to have some oxidation and rust. i think it will be to weak to hold fluid now
