Results 1 to 10 of 17
Thread: watercooling set up
    Chester UK
    Default watercooling set up
    how to set up watercooling with 2 res
    Overclocked Cagedconnerman's Avatar
    Apr 2006
    Near Sacramento, CA
    Default Re: watercooling set up
    how many waterblocks u gonna have?
    Chester UK
    i plan to have one for the cpu and gpu chipset already has good cooling
    Apr 2006
    Near Sacramento, CA
    w/ 2 rads and 2 blocks... I'd do pump>res>cpu>rad1>gpu>rad2. or you could do something with a y connector... res>pump>Y>cpu&gpu>rads1&2>Y
    p.s. before u go for this setup wait for someone who REALLY knows about watercooling, it works ok for me, but then again i didnt have heat problems to begin
    Chester UK
    thanks i was only planning on having one triple fan radiator and two res
    Apr 2006
    Near Sacramento, CA
    doh, sry...i i always mess up res and rad....i actually think it wouldnt matter where u put ur res's
    Razors Edge
    Guest
    How do you use a watercooling for a hardrive?
    Chester UK
    you can buy special made blocks that fit harddrives
    Case Wizard
    California, USA
    What is the point of 2 resevoirs? Is it so that you don't have to refill your system as much?
    I'm contemplating (and very new at) water cooling and never heard of 2 res in a setup.
    Chester UK
    actually its really just for looks
  1. Watercooling Quest.
    By Razors Edge in forum PC Cases, Tools, & Cooling
    Last Post: 08-30-2006, 10:03 PM
  2. Modders Challenge #1 - Home-Made Watercooling
    By Rankenphile in forum TBCS Challenges
    Last Post: 08-04-2006, 11:37 AM
  3. Watercooling Tutorial
    By jdbnsn in forum PC Cases, Tools, & Cooling
    Last Post: 04-12-2006, 08:34 PM
  4. Noob to watercooling
    By JOKER_JOKER in forum PC Cases, Tools, & Cooling
    Last Post: 10-30-2005, 08:16 PM
  5. FS: Full Danger Den w/c set up for Athlon 64
    By TheGreatSatan in forum The Trading Post
    Last Post: 06-28-2005, 12:27 PM
