Results 1 to 10 of 12
Thread: Parvum Extreme MbK
    Default Parvum Extreme MbK
    Parvum Extreme MbK
    Sponsored by:
    Hi fellow casemodders, Kier is back...again
    This time I will start with a great new acrylic case
    Probably you have seen it allready in the buildlogs from L3p and K.3nny, the new Parvum systems S1.0
    The case is individually cut and hand assembled, various colors and custom modifications possible
    When unpacking I noticed the very good quality acrylic (5mm high quality acrylic) ... very hard material to work with, but not impossible, more on this later. The layout is also beautifully engineered.
    The case is available from mid-March @ Highflow Parvum Systems S1.0 White
    And @ http://www.overclockers.co.uk/showpr...odid=CA-000-PS
    How it all started:
    After missing the postman two times it finally happened. A BIG package:
    Very well packed
    Hmm 2??? yes 2 Want to build something extreme.
    My kid really would like to know what it contains and whether it is for him .... unfortunately for him, these are for me
    Little picture with it from the two cases stacked.
    And a warning just in case ...
    A nice thank you letter from the Parvum family
    The black and white case with the following specifications:
    - Materials: Acrylic
    - Colours: Black/White
    - Dimensions (WxHxD): 275 x 305 x 420mm
    - Maximum CPU Cooler Height: 152mm
    - Motherboard Sizes: mATX
    - 3.5" Drive Bays: 2
    - 2.5" Drive Bays: 4
    - Cooling Front: 2 x 120mm
    - Cooling Rear: 3 x 80mm
    - Cooling Top: 2 x 120mm
    - PCI Slots: x 4
    4x PCI slots
    PSU opening
    Air outlet for the PSU
    Front fanholes
    And more 80mm fanholes at the back
    The mATX mobo tray, a hand bent acrylic mid-wall. Provides both case strength and the cable management
    With openings for the cables and possibly tubes
    The second case is slightly different internally and externally then the first original. Because I'm planning some fun stuff with this
    However, both with window
    Front is the same
    Furthermore the second case is empty, because I need only 1 hardware section. It is also slightly different at the back. 2x 120mm fanholes in the middle
    Also there were some nice extras in the package like:
    Case feets
    Some beautiful 240mm radgrills.
    And a 160mm radgrill.
    I also asked for some extra rest material for various purposes.
    Extra mounting stuff.
    Some last shots of the cases together
    To be continued
    Moderator TLHarrell's Avatar
    Jan 2012
    Morgan Hill, CA
    Default Re: Parvum Extreme MbK
    Wow! A completely acrylic case! I need to think about producing some designs... Looking forward to seeing your build.
    Update
    Sponsored by:
    Thanks for the comment... and now modding time
    The idea is to stack everything. The bottom with the hardware, then the radiators and on top the reservoirs
    So Rads + fans on the original part of the Parvum
    To reinforce the lower part a bit i've placed some aluminum strips. Just to be sure
    Used the existing cubes to mount the next layer.
    On each corner
    Cut some side panels to the right size and an opening for the fans
    Like this
    And cut two pieces black and white. Black has the same same shape as the original front below.
    In this there will come an Asus ROG logo
    Placed the radiators. Still need to make brackets for these
    Also placed the fans
    Looks good allready I think
    ROG logo will be added later
    For the back I have cut 2 panels with fanholes to the right size
    And placed it
    Testing the fans and gives me a nice shot
    And we continue with the next layer
    These will be all around with windows except the back. It will be the same height as the radiator layer.
    Update
    Sponsored by:
    This weekend received some great products for the build of Parvum from EKWB
    Thanks Niko,
    2x EK Coolstream XT 360
    2 beautiful EK-RES X3 250
    Some extra EK-RES X3 - Multiport TOPs
    And EK-RES X3 - TOPs to try something out
    Also some nice EK-FC7870 Nickel plexi water blocks
    And offcourse the EK-FC7870 black backplates
    Next update coming right up
    Update
    Sponsored by:
    So my modding friends time to end this Easter weekend with a big update.
    Asus also joined the party for this build. And they have send me a great motherboard.
    Btw. I have expanded my photo gear so the pictures will look like a bit different than normal
    The Asus Maximus V Gene
    The accessoreis:
    And the beautifull motherboard
    •LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
    •Intel® Z77 Express Chipset
    •SupremeFX III - Supreme Sound
    •GameFirst / Intel Gb LAN – Frag Without Lag
    •mPCIe Combo – Give Your PC A Power Up!
    •NIVIDIA® SLI™ / AMD CrossFireX™ Technology Support
    •LucidLogix Virtu MVP - Up to 60% Hybrid Graphics Boost
    Thanks Sven
    Also placed the EKWB EK-FC7870 onto the GPU's.
    Placed the nice FC7870 backplates
    Time for some modding. Om top of the Parvum I placed the resevoirs, with here and there some acrylic tubes
    The outlets
    The inlets and one of the fill ports
    Everything straight
    And a total shot
    Placed top and mobo
    Installed the EK-Supremacy. Did some brainstorming for the tubes
    CPU outlet to the GPU inlet
    Then go right
    Placed the pump about as posted on the HDD cage, more about this later
    To hide the HDD/ SSD I have cut some acrylic. Also filed and polished
    Glued together with ACRIFIX
    Just a few more.
    Placed the pump onto the last plate.
    This week I will receive the last panels for the top after this it's time to do some last things
    sleeving and connect all the tubes.
    Grtz.
    Looks amazing! Keep up the great work!
    Update
    Sponsored by:
    It took a while but here it is... the long awaited update:
    First my thanks goes to Freddy for nice discounts on the so important adapters / fittings and other stuff.
    Mayhems Pastel - Red
    Bitspower 2xG1/4" Fillport
    Bitspower G1/4 Matt Black 90 Degree
    Bitspower G1/4 Matt Black Multi-Transfer Adapter
    EK-PSC Adapter 90 degree
    And offcourse the Bitspower Multi-Link C47 Adapters
    I also got the last custom panels from Parvum systems
    Top side panels with window
    And with made by kier in it
    Front also with window
    A beautiful ROG logo in the front
    And a big window on top
    Side windows I allready had, but just nice to show when everything is in it
    Total shot
    Time to connect
    Placed the 2e radiator with fans and the fittings/ adapters
    Front (Used silver for lack of ...)
    Added some red details
    Other side was a bit tricky, but made a panel ​​to hide some cables
    Then....
    Filling!!!
    Put a roll of toilet paper in the case and here we go
    Great color red
    Let it run for a while. And no leakage
    Here the pics of a filled Parvum case...Extreme
    That's it for this sunday
    Final Update
    Sponsored by:
    Here are the final pics my modding friends, sit back and enjoy
    Lets go outside
    Power on
    My apologies for the huge amount of pictures...but I couldn't choose
    Special thanks goes to:
    Justin from Parvum systems
    Freddy from Highflow
    Niko from EKWB
    Sven from Asus
    You guys are the best :clap:
    And thanks y'all for the great comments
