I need a small 12V DC water pump. It doesn't need to pump a whole lot, it just needs to be small and quiet and run off 12V DC. 1/4in inner diameter tubing wouldn't be bad either. Thanks.
-Daniel
-Daniel
I found this. I'm not sure if I'll be able to modify it to be DC powered or what the pump is like on the inside but it isn't very big so that is good and it isn't expensive, so if I mess up or it turns out it sucks, I'm not out much.
Please help if you can. I'd like to just find the perfect pump, ya know?
Google "Dangerden".
I've looked there. Nothing is small enough.
Originally Posted by d_stilgar
Christ.
What, do you want one the size of a 9v battery?
how about this one? it's 2.4 x 2.4 x 1.7 inch 12 V but it has 3/8" connections..
http://xoxide.com/swiftech-mcp350-pump.html
hmm....aquarium water pump. Good idea, Stilgar.
-Dave
I've seen that one before. It's actually pretty small. I may end up going with it.Originally Posted by silverdemon
I'm not sure if you are being sarcastic or not, but if you aren't, thanks. It would require modification though.Originally Posted by DaveW
No sarcasm. It tends not to work online anyway.
-Dave
http://www.dangerdenstore.com/produc...0&cat=4&page=1
Cheap, small, nice, g1/4 threaded (Any fittings you want), annnnd I dunno what else.
