Well I had a cheap compUSA case laying around that needed a desperate
redo, so I decided to do a mod.
Not knowing what theme I could use for it, I thought of a good one while
playing COD2. Why not make a soviet themed computer? They have been
around in almost every popular war game.
The first thing I want to do in my mod is get rid of the ugly blow hole side
of the case and make a window. Using measurements and a little trick
from Modders Inc. I drew out a window.
For cutting, I used a combination of the dremel and the jig saw.
Ouch!
For the side that does not have a window, i decided to have a golden
backlit hammer sickle. Cutting it out meant having to make a stencil in
photoshop.
Again using careful cutting and just a cutoff wheel this time I cut out a
hammer and sickle.
This is a rough sketch from sketch up.
The three ducts at the top will serve as blow holes for the koolance water cooling system im putting in.
i have a bunch of lexan in garage stored which im going to spray goldenrod yellow and backlight. thats what
im hoping to get done today.
as for three ducts on the top. im trying to get the look of a Nuke generator which were used alot by the
soviets. i was looking around modders inc and i like the way Defyant has been doing them.
This Defyants mod down here:
