Results 1 to 8 of 8
Thread: hard drive and dvd drive not working
    May 2006
    philadelphia,PA
    Default hard drive and dvd drive not working
    i just put togather my new computer and it seems that my hard drive and dvd drive are not getting any power to them, im positive i hooked them up correct, what did everybody use to hook up their cd/dvd drive and hard drive with.
    hd: Seagate Barracuda 7200.9 ST3300622A 300GB Ultra ATA/100 7200RPM Hard Drive w/16MB Buffer
    dvd+rw: Pioneer DVR-110 / DVR-110D 16X Dual Layer DVD±RW Drive
    Dude...totally!
    May 2005
    Chico, CA
    Default Re: hard drive and dvd drive not working
    are they on seperate channels/cables, or are they sharing?
    May 2006
    philadelphia,PA
    Quote Originally Posted by AKA_RA
    seperate, i just have one of each, one ribbon cable going from dvd drive to motherboard, and the same with my hard drive
    Fox Furry crenn's Avatar
    In the shadows behind you
    Sign onto AIM and I'll see what I can do to help you.
    Dude...totally!
    May 2005
    Chico, CA
    we figure there was some miscommunication with a computer tech he talked to, and he hadnt plugged the molexs, so it should be working now
    May 2006
    philadelphia,PA
    and it is
    Dude...totally!
    May 2005
    Chico, CA
    awesome
    Rankenphile
    Guest
    hooray! trophies all around!
  1. my stupid dvd burner
    By specter539 in forum The Rookie's Nook
    Last Post: 12-23-2006, 02:56 PM
  2. Need help with my dvd drive.
    By .jrauck in forum The Chatterbox
    Last Post: 08-19-2006, 09:43 PM
  3. Hard drive mounting
    By pc1972 in forum The Rookie's Nook
    Last Post: 01-01-2006, 09:43 AM
